RCU Forums - View Single Post - JR28X Jet Programming
Old 09-29-2017 | 09:55 AM
Doug Cronkhite
My Feedback: (34)
Originally Posted by F4dar
Hey Guys,
Just upgraded to 28X from my 12X and trying to figure out how to setup my Flash (12 ch w/smoke), F4 (12 ch w/out smoke) like to add few additional functions in future. I have some basic questions per below, but more in depth help on setup. Looking for JR team pilot for guidance, if you are available, please pm me? thanks Jason
I am going to setup both jets with Power Center Hub/xbus connected to RG812BX RX, Powered Servo Converters for main flight surfaces, regular converters for other channels. (All PWM servos for now)
Basic Flight mode setup (3 modes) to include all dual rate/exp/trims
My Basic questions:
-If i activate Xbus in radio and Rx, can i still use throttle ch from PWM output on RX?
- How do you setup Throttle trim for jet (make it act like a slider) or some clever alternative? In addition the throttle trim goes in both +/- direction, confusing?
- Cannot figure out how to assign group trim to surfaces for each flight mode, the switch logic confusing me?
- There is servo speed, and delay for almost every transition/mode switching, Not sure which has priority, do I need to program in flap servo speed or i can just do delay, does it matter?
- Same questions for servo travel, dual rates, sub trim. I can limit servo travel in several different places? does it matter where you set it and what is the priority?
- I really need a simple explanation of how to assign 3position switches (logic).
I could also use the help if someone can basically list their setup on comp arf flash.
Tx for your help.
Jason
Throttle Channel - Yes, absolutely. You don't lose the PWM channel outputs.
For trim, 0 is neutral trim. +/- is simply each side of neutral.
By Trim for flight modes, do you mean so that individual trims are stored for each flight mode? If not, can you clarify what you're trying to do?
Servo speed is exactly what it sounds like. Delay refers to the setting having a delay from the time you activate the flight mode, to when the surface moves. So you could set your servo speed to 50%, which would slow it down, and set the delay to 0-10 seconds. So let's say you have your "normal" flight mode with a given elevator throw, but you switch to "land" mode, which has a different amount of elevator travel. Delay adds basically a transition time between those flight modes, so you don't get some crazy jump when switch modes.
Servo travel, expo, etc. can be setup as individual values based upon switch position.. As in you have a switch that changes elevator rates only, or you can group them in flight modes to change multiple settings via a single switch. It took me awhile to wrap my head about the programming logic here as well, and I've been flying JR for over 20 years.
While I'm in Afghanistan until Dec.. Feel free to contact me with any 28X programming questions you need help with.. I'll do my best to resolve them, or point you to someone who can..
