RCU Forums - View Single Post - Servo wiring question
Old 10-15-2017 | 01:14 PM
Dave13579
Default Servo wiring question
ID:	2241290Click image for larger version
ID:	2241291Click image for larger version
ID:	2241290I am running wires to each of my servo's in this wing. One for the flaps and one for the aileron, I also wanted to run the wires to the landing and nav. lights out to the wing tip, using the same hole I put in the ribs. There will be like 10 wire touching each other..... As you can see in the photo they will be twisted, but will this be a problem with interference, when I operate the servo's? There will be something like 45 inches of wire in both wings. Should I make 3 runs of wire, 1 for the lights, 1 for the Flaps and 1 for the ailerons,?
Thanks Dave
