Keep the nose slightly down on approach. Once its leveled out about 1' - 2' above the strip, keep the nose up slightly until the plane lands itself. If you try to set it down before its ready, it will bounce. The UF is scary fast. If you try to fly it slow it will stall. I have been flying jets for 3 years and this move to a UF was a huge change for me. Probably not a good jet to learn on. Make sure you get an experienced UF person to help. I had several very experienced jet pilots helping and was getting conflicting tips until I linked up with a UF pilot. Good Luck!
