RCU Forums - View Single Post - help with receiver position?
Old 10-25-2017 | 08:06 AM
jetmech05
Default Makes no diff
As far as reception goes it makes little difference. As far as CG goes now here's a problem. You want your CG to be slightly nose down with an empty tank. Adding weight can be done but it's better not to.
So get your CG set and move your receiver and battery around to achieve slightly nose down.
As you fly more you may find you want to move your CG aft a bit..
