Temporay fix for bug
Bill,
Thanks for the reply.
I have found a work around for setting the throttle failsafe position setting, until the bug is corrected:-
1) Set up the model configuration in 7 channel FASST mode, as normal, except throttle failsafe.
2) Switch the FASST MULTI mode and set the throttle failsafe position.
3) Switch back to 7 channel FASST mode and test the throttle failsafe operation with the model.
The position set in MULTI mode seems to remain, when the transmitter is switched back to 7 channel mode and works with the R617 receiver.
Regards,
Ian
