Originally Posted by
speedracerntrixie
I know this may be a can of worms but what we currently do in pattern is not what I would call a snap roll. I seriously doubt that the airplanes enter any amount of stall. The fact that we are able to stop rotation instantly by simply releasing the sticks tells me that the wing is flying the whole time.
Yes and no. If the rotation rate is only about 360deg/sec and you go into it at about 80km/hr then the 1/2span section outwards would be seeing about 8+ degrees angle of attack, the tip would be seeing about 16 deg. Throw in some minor pitching and you've probably got about an outer 1/3rd of the wing panel "stalled".
I do believe though that loading up the wing before commencing the rotation should be required, because the increase in roll rate should come from the imbalance of lift (stalled panel vs unstalled panel) not from increased aileron throw..
I also believe snap rolls have no place in pattern whatsoever....but....
