RCU Forums - View Single Post - Transmitter configuration
Old 12-02-2017 | 01:59 PM
rgburrill's Avatar
rgburrill
I'm with doing the mechanical changes first. It sounds like you have them in the wrong place. Moving in on the servo or out on the control surface horn reduces the end point. Likewise moving out on the servo or in on the control surface horn increase the endpoint. The best way to do this is to set the transmitter to it's maximum deflection and adjust where you connect the pushrods.
