RCU Forums - View Single Post - Can a Delta Wing have flaps?
Old 12-07-2017 | 11:13 PM
mikes68charger
My Feedback: (34)
Thanks. I should of posted. I got 11 flight or so.
I use just the out bord controls as elevons, and make the inside ones come down about 15deg as flaps which cause more drag, it’s like crow. Helps to kill the ton of lift and slickness of the fuse.
I cant believe with all the added weight of my turbine conversion I have to shut the motor off to land or it glides forever!
Thinking of making a takeoff mode where the inside controls will follow the out side elevator just to takeoff.
This is this is so aerobatic it’s amazing to fly
