RCU Forums - View Single Post - Caressa by Bryan Hebert of CK Aero
Old 12-31-2017 | 09:25 AM
  #39
Smooth Pilot
Have not updated for awhile so here is the latest. Could not get a good level knife edge pass by adjusting the CG, so I gave up and did a little bit of rudder to elevator mix to cure that. It does not appear to affect the other flight parameters so I will stick with it as it is now. I finally had to replace the aileron/elevator springs with some that were a little stiffer as I could not get enough tension with the adjusters so all appears well now. I have a little over one hundred flights now and everything is settling in real well. Now if I could just get the sequence memorized....
Sheldon
