Originally Posted by
MARK JR
Alright, do you epoxy the firewall first or install the engine first? How do you start the gasoline engine with the choke on or off? Thank you guys
Many builders mount the engine to the firewall first, because it's easier to drill the engine mounting holes, and install blind nuts. The engine is then removed, and the firewall is installed on to the fuselage.
Refer to your engine's operating manual for the correct starting procedure.
