RE: Tango Assembly
Next, I assembled the intake. The corners were missing a little glass that left an opening visible when installed. To fill the missing corners, I placed a band of masking tape around the area that that needed slight filling and from the inside, placed a bead of aeropoxy. Smoothed the aeropoxy out and let it set over night. Once set, the tape was removed and the aeropoxy shaped up with a dremel drum sander. The fit was checked and adjustments made with the dremel till it fit perfectly. I then CA'ed the intake in place followed by aeropoxy.
Todd
