George,
Thanks for the follow up. Now I’m really concerned and will have to come up with another plan for my new model. I would have thought turning the gyro off would work as a bail out plan.
Since my plan was to use a Rex 10 assist (not a 11 as I listed above), our equipment is not exactly the same but still raises concern. Perhaps I’ll pull the Rex 7A out of my test bed plane (cheap foamy) and install the 10 assist to see if I can duplicate your issue.
Would you you confirm your wing type? Delta, 2 ailerons/2 flaps, tail type?
Thanks!
John
