Hi Shawn, Scott,
I was curious about Divinylcell and googled it. Wow, that stuff is lighter than contest balsa. What do you think about using it in all balsa construction? I was thinking of laminating 1/16 balsa to the outside and using it for fuselage sides; I'd reinforce the inside too depending on the location in the fuselage either with open framework or more 1/16 balsa or maybe ply around the firewall/landing gear areas.
Thanks for your thoughts!
-Will
