can you be more specific on the CG or balance point
This model has no weight, the ECU pack is a std Li-Fe 2100mAh JetCat item, I'll probably move it back as fat of fuel, it is a little nose heavy. Weight is around 22lb with a little fuel.
Balance is at 6" forward (wing root) with MAP full and some fuel in the 32oz Dubro. (6" forward from where ?)
Did I say-I really like this aeroplane
__________________
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Airtech Germany, Jet Tronics.
