RCU Forums - View Single Post - Caressa by Bryan Hebert of CK Aero
Old 01-30-2018 | 12:05 PM
  #50
grotow
Originally Posted by Smooth Pilot
The battery tray has been placed in the plane with the batteries to set the CG. As you can see the CG balances at the rear of the wing tube. The tray has been appropriately marked and will be installed using a removable tray system. I purchased the removable tray kit from F3A Unlimited, but could only use part of it for the front mount. I had to get a little creative to complete the mount, but I figured out something. All control throws were set to Bryan's instructions with the exception of the snap roll recommendations. Snap rolls are not in my sequence at this time, so I did not bother setting them up. All that is left now is to program the ESC, adjust my throttle curve to keep from over-amping, and add some packing tape to the canopy to improve the air flow over the batteries. Final pictures will be forthcoming. I hope to get with Bryan this weekend or as soon as he is available to get the maiden flight and trim set up. Of course, that will result in a flight report.
Sheldon
Could you post a picture of the rear battery tray underside installation? Thanks
