Sounds like low voltage cutoff might have kicked in .
Do you have a voltmeter that you can check your battery is charged properly ?
Try your friends battery and also try using his charger to charge your battery and see if it still happens .
Then contact Redcat directly .
A good Hobby shop would at least try to diagnose what the problem was !
