RE: reciver, trans hook up for flaps?
Thanks alot I do have a servo reverser but didn't think I needed it with a computer radio. I also have a Y connecter. The transmitter has a glider setting and you select either 4 wing or 2 wing meaning the number of servos. Mine is a 4 wing and each servo has a channel to plug into on the 7 channel reciver so in that mode it works everything. Did have to set the EPA for the flaps (after re-gluing my horns) and it works good. I dont like the throttel so untill I can figure out how to hook it up in acro thats the way I will fly
