Originally Posted by
Tidnab
I believe the hull you have is an Enforcer crackerbox which is a shallow v hull.The giveaway is the cross member that divides the engine compartment from the radiobox section The rear opening should have a hatch cover that two drivers sit on.You could get the 50mph ,but not with that weedeater engine, even with modifications. A Zenoah 260 should get you near that 50mph. The crackerbox is a wild handling hull that like a full deep vee,and requires learning to drive it,but when you do it is a blast.
I noticed it did not have turn fins. I plan to order the upgraded rudder system and all new rear parts kit including a new prop. Could someone recommend a good prop for this boat? Im just going to get it ready to sell then along with my Pursuit mono hull that took 2nd in NAMBA regionals 3-4yrs ago. I will post a few pics of both of them in the next 2 weeks. My next boat is gonna be a Cat, cause I caught that "Cat scratch fever..." Hahaha
