What ECU do you have? If the PW is at 1000 plus it sounds like something is not right. Perhaps try another pump. The JJ ecu does not allow you to change the pw limit where as other ecus do. You also might want to try another pump just to rule things out. How does the engine run at 75K. rich, clean, flames? This is ~70% % of max.
Andy
Originally Posted by
Madpatty
Hello All JJ owners,
I need your help with the JJ1800 turbine which I recently bought.
When i tried running it with all batteries charged (Starter and fuel pump battery LiPo 2s 2200mah), the engine won't go above ~75000rpm with pump Pw on first screen of data terminal reaching 1005 units.
I checked all the fuel lines for blockages etc.and found nothing.
Has anybody had this problem before.
Thanks.
Madpatty
