RCU Forums - View Single Post - Phoenix Models Tiger 3 ARTF
Old 02-24-2018 | 10:47 AM
  #37
thailazer's Avatar
thailazer
Taking some measurements today and looking at the wing mounting, I see that the right wing panel has the hole drilled about 1/16 inch off where it should be, and it is drilled off at an angle much different than the other wing panel. Appears it was drilled out with a hand held drill. The left wing panel is right on so I can use that as reference as I figure out how to correct this issue.
