RCU Forums - View Single Post - CARF Galloping Ghost build
Old 02-24-2018 | 03:25 PM
  #68
rbgetz's Avatar
rbgetz
I made some tab's for the hatch out of G-10. Then used blind-nuts and decided to go with 2-56 x 3/8" flat-head screws that I'll counter sink slightly. It will have a clean look on the outside with the screws set in. When the plane is upright, you really can't even see the hatch. I CA'd all tabs in place and then put a bead of hysol around everything once it was all lined up. Definitely open to see how others solved this. I'm also open to suggestions. Rob
ID:	2255841   Click image for larger version
ID:	2255842   Click image for larger version
