Originally Posted by
aaronforth
I would think the same goes for Jeti. Power must be interrupted to reset the fuel.
Yes, I'm using this setup on Jeti, works fine. Route the power (positive wire) for the FC-1 through one of these:
Turnigy Receiver Controlled On/Off Switch and use a spring loaded switch on the transmitter to momentarily interrupt power to the FC1. By the way, this also works fine using Futaba.
