Question for the day. When installed, should there be a gap between the inlets and the fuse, or are the inlets supposed to be glued to the side of the fuse? With this gap, there is a small gap on the opposite side with the cowl. If I glue the inlet to the side of the fuse, Ill have to cut an area out of the splitter plate to slide into. Right now the splutter plate will slide in the gap and the cowl has the area cut out for it.
