These are the formers for the horizontal stabs, these brackets attach to them, and there is a ply doubler that joins them together. Are these good to go? I noticed on some of the newer models these are carbon fiber, should I do anything to them such as cut new ones and double them up or make them from thicker ply? The tail section they glue into has CF reinforcement, but strange these formers take all the force of the tail, I figured they would be thicker all across. At the joint they will be 1/4" thick but the brackes still only hold onto 1/16" wood.
I think this is my next step but will check in the manual, still need to install vert fin former and the former that the bypass goes through, so Ill check I wont make one part harder then it needs to be by doing them out of order.
