Originally Posted by
jjoos99
I have an older non pumped version of this engine. It has been in the plane for several years and only started and ran once. Just wondering if I shouldnt just go ahead and buy the pumped carb and install a pressure port? I hope to join a club and finally fly it this season. Looks like the carb is around $35
thanks
Jeff
Jeff... You didn't outline the specific reason the engine was run only once so it is hard to say if you should upgrade the carb.
I've two of the vs 1 engines and haven't had problems so continue to fly them with the non pumped carbs. If they were a problem, I'd upgrade them.
