RCU Forums - View Single Post - New Evolution 10cc gas engine
Old 03-14-2018 | 06:12 AM
  #2208
jjoos99
My Feedback: (12)
Originally Posted by AA5BY
Jeff... You didn't outline the specific reason the engine was run only once so it is hard to say if you should upgrade the carb.
I've two of the vs 1 engines and haven't had problems so continue to fly them with the non pumped carbs. If they were a problem, I'd upgrade them.
I was flying at a runway behind my home and lost the use of the runway so the plane I had bought this engine for has never flown, just test run in the back yard. Hasnt been started since 2016. I just thought that if it needed done now would be a good time while snow is still on the ground.
Jeff
