RCU Forums - View Single Post - Question on Grease
Old 03-24-2018 | 08:56 AM
Fsttanks
Originally Posted by armshark
Good day all,
Any recommendations for greasing my tanks. Do I need to use different kind of greases for different components of the tank; gearbox grease, bearings grease etc. One more thing, I heard WD40 isn’t a good substitute for grease, as it just displaces water. Is that true? Appreciate if you guys could share a little bit on this subject. Cheers.
Shark
I use Mobile 1 red synthetic wheel bearing grease in my gearboxes. They run butter smooth. I have also used 20/50 synthetic motor oil in my gearboxes. It too worked well but needs to be reapplied more often. The road axles shafts can be greased/oiled but you will collect more dirt on them. It is a win loose issues, it helps, but also increase the need for additional maintenance/cleaning depending on how much dust, dirt, mud and sand you run in.
Just my .02
