I would check the current draw of the servos. It may be too much for the Clark board and causing a brownout. If you can use them both directly off the board before connecting to your linkages but afterwards it doesn't work then there is a chance it is pulling too much current. You can try using a dedicated BEC or smaller servos and see if this fixes the issue. What servos are you using?
