Originally Posted by
armshark
Thanks for the reply gp100, it really helps because as an experience RC-er like yourself you would know that there is a whole plethora of greases out there. So many different kinds and purposes argh! It’s a little intimidating really and I could spend a day researching about greases it’s crazy. Thanks again gp100! Cheers.
Shark
You are very welcome,
In the years I've designed and worked on electronics, I've seen it all.. And have seen first hand what even one drop of oil can do to an electronics board.. That's why I always tell people to use grease.. Much safer option all the way around. You invest a lot of money into this hobby. It only makes sense that you guys want to protect that investment the best way you can.
I'm glad I can be of help here on the board.. I'm always here to help where needed if I can..
Here's the grease I use on my tank and many other things. Same stuff as Moly Grease, just under a different name.. I buy 2 of them at a time because they are small tubes. But you don't need much anyway..
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Here's another that's really good as well.. It'll stand up to wet, dry conditions. Heat and extreme cold. I use it as well in some of my RC Cars. Never had an issue. Great stuff.
https://www.amazon.com/Team-Losi-Gre...4B0NV3F29M0P0H
There are many great products out there that will do the job.. These two are just my go to grease. But you can no doubt find many other great options out there..
Enjoy!
