Thank you Allan!
The wing has 4 ailerons. I would like to use all 4 as ailerons, and then with Flight Mode I would like to use the inner ailerons as flaps while the outer ailerons function as ailerons. Currently, everything is assigned through xBus...using sub ID’s 01, 02, 03 and 04 on the aileron channel.
It is my understanding that Flapperons won’t let me have dedicated flaps.
I’m still very perplexed by the Device Select screen. The channels for Gear, AUX 2 and AUX3 are occupied with aileron OUT. I’ve assigned 4 servos to one channel through xBus, yet the Device Select screen has ailerons assigned to other channels (plus RAL1 is nowhere to be found).
Disregarding that confusion for a minute, should I be using two aileron sub ID’s and then set the two inner ailerons to Flaps? Then, in Flight Mode set up a mix? It would be nice to use a slider switch for the flaps...
I explained my issues to the folks at JR America and they are having one of the factory guys call me...haven’t connected yet.
Thanks again Allan,
Tom
