last tip
practice this move on G-2 with a the cap or 300 and you will have this move down very quickly. Yes you do need to have a slow roll down pat both left to right and right to left. rolling to the otherside is harder IMHO but once you have slow rolls down you can do like the big boys and do one to the inside then one to the outside durning the same circle. last a good rudder auth. plane like the sig cap or DP bipe will help you out like you would not believe.....once i state to roll my ailerons hardly moves from here its rudder and elevator and sometime throttle ......DP showes this move on wing it out volume 2 or 3 .........
