Allan,
JR Americas had directed me to LaDon who had helped me out on this as well at one point.
The thought is that there is potentially one little difference between our transmitter programming that is causing them to behave differently. That may be supported by the fact that I replicated my results when I set up a dummy test model (to go with the dummy test model operator).
By way of suggestion, they said to do the following things, in this order:
1. Email your transmitter set-up for this model so I can copy it to my SD card and load it into my transmitter (pretty confident this will work);
2. If #1 doesn’t work, then upgrade my XG11 to the same version that you have (which I believe is ver 13)? Even though the only change with that is supposedly airplane gyro, he indicated you never know if there is another little change and/or fix in there somewhere that would make a difference;
3. Run the radio over with my truck (my next step) !
So there you have it!
How do you feel about emailing the model you have in your transmitter to see if it runs the same way in my XG11?
Can’t thank you enough Allan....
Tom
