Tom,
I'm glad that you were able to get the XBus channel nomenclatures to reflect their functions and match those in the MONITOR.
The channel ID stored by the XBus servo and converter harness is probably in the same numeric format used before version 12 upgrade. When I programmed the 4-port XBus converter harness for my sailplane wing, the default names I had to use were LAIL-01, LAIL-02, LAIL-03, and LAIL-04 because in the GLID configuration channel #1 is the left aileron, not the throttle. If changing AILE-01 (left aileron) and FLAP-01 (left flap) to AUX3-01 and AUX5-01 on your transmitter didn't work, it could be that the problem went deeper than the XBus names not corresponding to the names in the MONITOR.
The pleasure was mine in helping. I learnt something new about the XG11.
Allan
