RE: VectorFlight 300s, anygood?
Can't help you with the wing Miloh. Mine is the Edge and it's 2-piece. Sorry.
As for the cowl touching something, take a look at this:
On the inside of my cowl where the hub exits, there was a big lip around the opening. Everytime I tried fitting the cowl, I met resistence and I couldn't find where it was hitting. When I finally found it, took a dremel sanding drum to it and 5 seconds later everything fit fine.
Check it,
John
