RCU Forums - View Single Post - CARF Galloping Ghost build
Old 04-18-2018 | 06:02 PM
  #79
rbgetz's Avatar
rbgetz
I got the engine installed and the throttle and choke linkages all connected. things get really tight up front. Installing the engine takes some orchestration. example: getting the spark plugs cables connected as you're installing is a little bit of a challenge, also aligning the throttle linkage while installing a 16 pound engine in one hand wasn't easy. . To help with the CG, I was able to get the ignition and fuel pump batteries all the way aft under the hatch for the tail wheel assembly. I hope to get the fuel tank and RX installed as soon. I won't install the two RX batteries until I do a weight and balance check and then put in place the for final balance..
using some foam, the hatch will compress the batteries and hold in place
Ignition and fuel pump batteries
