RCU Forums - View Single Post - CARF Galloping Ghost build
Old 04-25-2018 | 05:23 AM
  #93
Jonboy2
My Feedback: (62)
Hey Rob,
Question for you—I will be using the APS fuel pump with my 155. It is the pump that Gotz sells and recommends for this motor. Could you please tell me how you set up your fuel pump for your 230? I think I got it all plumbed correctly from the tank to the carbs. Just wondering as far as programming. I am assuming you don’t want it running at full pump capacity at full throttle. I thought I had read somewhere to program full like at 70%. Also, do you have your your programmed to your throttle stick or is it just on or off by flipping a switch on your transmitter? This is the first time I have used this type of external fuel pump and just not sure of its proper operation and set-up. Thanks. Jon
