Originally Posted by
flywilly
Very interesting, Jim. I have always had good results releasing the rudder a bit early, myself. Can you program those exact inputs into a snap switch? ...and is that cheating? :-)
-Will
I have tried setting up a sequencer to do the rudder automatically, but was not happy with it. I couldn't get the exact timing with the sequencer I had. It could probably be done if one wanted to spend a lot of time but I don't think it would be worth it. Probably too aircraft speed dependent. Cheating? Not if your object is to perform maneuvers better. However, if you sign up to obey rules written by some elitist governing body, you better follow their rules.
Jim
