I finally got the internal hull bracing done. I like to use acrylic on the inside of the urethane hulls I use because they can tend to get soft and warp in the sun. Lots of bracing inside, Im not as worried about this hull as the urethane seems to be more brittle than the stuff nick uses.
Also got my fenders made and installed along with one front fender. The other is half done but I have to finish that side of the hull first. It was warped there and would not square back out even after heating and it broke. I repaired and am just building up the shallow spot and will remake the weld line when finished then install the fender.
I had tested it out on the ibu last week and all tested well. Its coming along nicely.
