Yeah, I realized the counterweight on the turret needs more rear shape with this photo. I will do a bit more but its a bit late to make many changes there. I wish I had seen the east coast armory urethane one before I did my build but I was already done with the turret mods when I found his site for detail parts. I may try to add the side slant to the mantlet, not sure. Its not that obvious and will be a lot of work to try and do right. I know there are still details not perfectly correct with this overall build through all the research I have done, much of it cant be helped when you use this chassis and that guys cast hull and that persons designed part and that guys details and that mfrs etc etc. The MG port on the bow is a good example along with the strip I had to add at the bottom of the glacis plate. Its really tough as I spend more time staring at the model with photos and a pencil and ruler than I do actually making or installing parts.
