RCU Forums - View Single Post - New + Strange problem
Old 05-30-2018 | 05:27 AM
Imex-Erik's Avatar
Imex-Erik
Originally Posted by Crius
Erik, the JT uses the 58 mm shaft, right? I might have one at home I can send him, I'll check it out when I get home from work.
Yup, takes 58mm for the JT chassis. Where is the Hetzer?
Originally Posted by Kear-Skof
Glad to see that the shaft design was revised! On a tank as heavy as the JT it quite needs them. But I'll most likely see if I can get some piano wire to fix the shaft, mostly just to see if I can at all.
It wasn't a big problem on any specific tank really, just one more little thing to improve that helps all the gearboxes. I only had a handful of complaints but everything gets passed on.
Let me know if Crius can't take care of you, I got a ton of them of all sizes.
