RCU Forums - View Single Post - IBU2 Pro Problems
Old 05-30-2018 | 09:29 PM
Shark27's Avatar
Shark27
I believe Tamiya uses 940 nanometer IR LEDs you can buy 50 of them for less than $7 on Amazon or Ebay. For battling you just need to make sure it is mounted in a tube that has at least 9mm from the front of the tube to the front end of the LED, this prevents scattering the IR beam and causing friendly fire amongst your teamates.
Steve
