RCU Forums - View Single Post - VectorFlight 300s, anygood?
Old 11-01-2003 | 02:25 AM
  #424
Miloh
Default RE: VectorFlight 300s, anygood?
David Moen: The cowl will only go so far onto the front of the fuse. At the point that the cowl stops My motors shaft was still hidden inside the cowl. the only way I could figure to get the cowl far enough onto the fuse for the shaft to potrude enough to put a prop on it was to cut the back of the cowl off so it would slide further back on the fuse.
Did this all work out for you without cutting the cowl?? if so what motor and mouht did you use?
Miloh.
