RCU Forums - View Single Post - Did a wheel model on my Apprentice S 15e
Old 06-04-2018 | 09:32 AM
rgr4475
Originally Posted by H5606
Thanks for sharing.
The mismatch you're referring to is normal - most tricycle gear airplanes have a smaller nose-gear wheel than the main-gear wheels since the mains carry a majority of the load.
Passing on a technique someone told me about to improve the look of those Dave Brown wheels: stick the wheels in the freezer for a while to stiffen the foam tire, find a long screw and nut to use as a mandrel that fits the axle hole, then chuck each wheel up in a drill press. With the drill press running, use a Dremel and sanding drum to shape the tire and give them a more pleasing rounded cross-section.
The stock wheels all came the same size but I have noticed that. And what a smart idea putting the tires in the freezer. Thanks for sharing that!
