in most larger oil injected 2 cycle engines the oil metering is proportionally connected to the throttle . as the throttle opens the oil delivery increases and vise-verse. if you are using this oil as a lube for valve train protection, you might be able to set up some linkage to work the same way off the throttle servo. as a throttle servo is very under labored...... there should be plenty of reserve servo power available to easily run another system. proportioning can be achieved through slave levers and/or belcrank(s) to increase, decrease, or reverse pushrod travel to the oil metering valve in proportion to the throttle rod travel.
as far a pump goes. the oil tank could be pressurized by a tap in the crankcase of the engine, using secondary compression or off the silencer, as fuel tanks are pressurized, to pressurize the oil tank, rather than using an electric pump.
Reason: additions
