RCU Forums - View Single Post - Kingtech JMB jets 3m PC-21?
Old 06-27-2018 | 06:40 AM
  #53
Neil Guildford
I discovered that the top of the fuselage section in front of the canopy was starting to crease where I was turning the model over to rest it on a stand to put the wing it on, so decided to lay carbon weave mixed with zpoxy to the inside.
The powerbox smoke pipe melted where I connected it to a brass fitting at the manifold, so exchanged this for a gas fitting of 8mm external and 4mm compression on the other end. Connected to this is a length of 4mm brass tube which is connected together in a Y before the pump.
Lastly, painted the supplied spinner for a better colour match to the cowl.
Tests on the running temperature will be carried out next.
