Originally Posted by
Ekvien
I would choose an engine thats gives enough power in uplines and brakes in downlines. 4 stroke engine like YS 115S could be a solution. Old 2 stroke pattern engines is just for speed and you have no brake in down lines. Most of the patternship mentioned as 90 size flies better with engines around 110 - 120 size.
thanks a lot for your kind advice! I was completely unfamiliar with the concept of “breaking in the downlines”. Could this be achieved with the old 2 stroke by using a larger propeller?
my only concern with the YS is the high cost of the engine and that it does not fly with FAI fuel. I live outside the US, where it is impossible to buy nitro. Hence my inclination for a DLE or using the Rossi that I already possess.
