I see from the other treads that one person gives advice about tuning in the pipe so you could run a bigger prop, that could also be a solution. Since you not have access to nitro fuel maybe as mentioned in the other tread that OS AX 120 could be an option. Weight to power ratio is the problem with gasoline engines, but of course, easy access for fuel. Is it possible to electrify the model?
