RCU Forums - View Single Post - Excelleron 90...WHAT ENGINE!?!?!
Old 07-12-2018 | 05:12 AM
morsilla
Originally Posted by Ekvien
I see from the other treads that one person gives advice about tuning in the pipe so you could run a bigger prop, that could also be a solution. Since you not have access to nitro fuel maybe as mentioned in the other tread that OS AX 120 could be an option. Weight to power ratio is the problem with gasoline engines, but of course, easy access for fuel. Is it possible to electrify the model?
Thank you Ekvien! Yes, maybe that would be an option, to make it eléctric. This kit was designed for nitro, but I guess with so many hassles nowadays, it would be more practical to add a new firewall and make it electric. The only challenge I see is replacing the battery every time, since I would have to remove the wings every flight to replace the battery.
what engine/battery combo would be recommended for this project? This is a 1.70m x 1.70 m airplane, a bit heavy.
