RCU Forums - View Single Post - What engine is this? Sachs???
Old 07-31-2018 | 07:43 PM
Keefer
Red face
Originally Posted by CK1
It's for sure that it's a Sachs engine .You will need access to the face edge of the cylinder base flange to get the cylinder # . 44ZN is a 3.2 , 47ZN is a 3.7 and 49ZN is a 4.2 The numbers should be located just behind the flywheel shroud. You may need to unbolt the cylinder to raise it up enough to get to the numbers . I'm fairly certain its a 3.2 .
Thanks sir!
Odd to me that a manufacturer would hide their designators that way. I can easily pull the head on this one, but I have another buried in the nose of a 112" P-51. I'm not sure I want to go through that trouble to figure out the size.
