Originally Posted by
rcdavid
hi guy’s
I try to put 2 sensors for my jet on my 18mz
the first sensor is jetcat telemetry and second is powerbox sensor to read volt and mAH.
but i try to put the first jetcat sensor... the only slot working is slot 16 to 29. If i choose another slot , the sensor not working
and after i try to put powerbox sensor on my 18 mz . I choose register option , and i read register failed not enough available alors.???
i have slot 1 to 15 not used but qu’en i try to put sensor in this slot the sensor not working.
can i put more that one sensor ...can you help me working this please
thank’s
Dave
Hey Dave,
Not sure if Powerbox Sensor has telemetry output (I doubt it) but in any case with PB devices if you want to have telemetry output from Powerbox you need to use this device --> the Teleconverter-->
https://www.powerbox-systems.com/en/products/accessories/stromversorgung/teleconverter-s-bus-2.html .
I have tried it with PB Royal only and works perfectly. Please look at the pics below. Make sure you connect both the Jetcat sensor and PB to SBUS2 slot (not SBUS). Then change Jetcat to slots 1-14. 15 empty. 16-31 goes to PB.
Should be straight forward.
Tassos
